gixxer
Posts: 9 Joined: Sun Oct 04, 2009 7:39 pm
Post
by gixxer » Sun Oct 11, 2009 3:01 pm
Any suggestions why one of my carbs is overflowing. Have stripped and checked float height and all appear fine ?
Posts: 1549 Joined: Thu Jul 27, 2006 12:47 pm
Post
by scooble » Sun Oct 11, 2009 3:56 pm
check that the float valve isn't worn or obstructed - check by removing the carb, blowing down the fuel pipe whilst the carb is upside down
gixxer
Post
by gixxer » Sun Oct 11, 2009 6:01 pm
When I blow into the fuel pipe the valve does open and close when you invert the carb. The valve does not appear worn
Posts: 1546 Joined: Fri Nov 14, 2008 9:37 pm
Post
by pablo » Mon Oct 12, 2009 1:40 pm
It can only be the float height or the valve.Are you sure you hav'nt bent the small tang on the float
If not then make sure the pin is clean and the float is moving freely on it.Then its down to that valve or the valve seat clean them with good carb cleaner or better still replace them the're not dear.
Posts: 2120 Joined: Sat Jun 09, 2007 10:10 am
Post
by headcoats » Mon Oct 12, 2009 2:38 pm
The float can catch the little brass overflow tube if it is slightly twisted
gixxer
Post
by gixxer » Mon Oct 12, 2009 9:22 pm
Thanks guys I think the float was catching. I stripped the carb again and it seems fine now
