crank rebuild cost?
crank rebuild cost?
can anyone give me a rough estimate of the cost for a full crank strip, rebuild and ballance (including new rods, bearings and seals)?
buzinc
http://www.pjme.co.uk/acatalog/Kawasaki ... m_End.html
This bloke is highly trusted
mgtkr1
mj43
Matt
You could but all your port timing would be out and your expansion wouldn't match. More trouble than it is worth
I am quite happy with the 56 x 50.6 layout and the next Evo of my motor I am hoping will blow anything seen so far to pieces (might be an unfortunate use of words as I am already struggling to hold the motor together).
Just need a bit of time to make up the bits and test it.
Bearing Part Number
I offered up the crank to the crankcases yesterday and noticed that the right hand bearing locating Pin (not the flywheel end) did not sit in the crankcase recess. This lead me to believe that I may have the incorrect bearing fitted.
Does anyone know what this bearing part number should be.
I checked the Fiche on CMSNL, but it only list the crank as a complete assembly.
(BTW - PJ Engineering will only give you advice if you have a PJ Engineering invoice - which I don't)
buzinc
buzinc
buzinc
I had my RD250E crankshaft rebuilt a few years, the pins were in the wrong place similar to yours. When I contacted the re-builders (cant remember who) they said 'just in dremel in new ones'!
The bearings were the correct spec crankshaft bearings, just the pins (all 4) didn't match the locating groves in the crankcase.
I did dremel the groves and no probs ever came to light. But paying that sort of money, I think I would want the pins to match up.
