hi lee
when i bought it, it came with a spare smashed up belly pan
i cut the extensions from this
cut a couple of strips of alloy to link fairing to extensions and
drilled/screwed it all together
cut a piece of stainless steel sheet to bridge the gap between the extensions underneath
also made an ally bracket to connect r/h side to screwhole where
the overflow bracket normaly mounts to stop it moving around
didn't get a blue peter badge though
i'll post a pic at the weekend
know what you mean about the fairing - they seem to stop too short
and make it look a bit dated -it's not so obvious on black ones because
the fairing tends to blend with the exhausts
