Air filter support.....
falconman
Post by falconman »
Got bored yesterday so I made a new filter support as the one in the bike was a bit dodgy. I have not been able to find a pic of what is supposed to be there so had to wait until I had a good idea on what to build. Here is what the po had installed...
Here is the new one I made up, took about an hour. Works much better. It doesn't fall in and block the intakes.
smithyrc30
Post by smithyrc30 »
Nice job Falconman, a quick coat of paint and it will be fantastic.
The original was a plastic grate with one central rib length ways down the box (about 4mm across) and three cross ribs equally spaced along the length of a similar width.
They are not very robust.....
Yours looks much better. =D>
DIY air filter support frame
good job Jim
I cant take credit for this one - I inherited it - also from a Previous Owner....
here's an original KR air filter frame (complete with Armymen plastic flashing/sprues)...
...doesn't even lie flat
next to useless ... so flimsy...
falconman
Post by falconman »
WOW! :shock: :shock: After seeing the factory version I guess I did do pretty good! I used 1/8" (just over 3mm) welding rod, cut and bent each piece then laid out on an aluminum plate to weld. Now that this one is done I can use it as a pattern to make the next one in stainless. The next time I get bored. :lol:
NOS EXUP
Post by NOS EXUP »
See new item from BAM RACING - just bought one - perfect fit
on ebay
NOS EXUP wrote:See new item from BAM RACING - just bought one - perfect fit
on ebay
Can't find them on eBay. Link?
NOS EXUP
Post by NOS EXUP »
Item No 170558196666
NOS EXUP
Very nice. eBay seller is bammotorsport if anyone is searching.
air filter support
http://shop.ebay.co.uk/bammotorsport/m.html
obviously someone that reads this forum :!:
is nice
but how about an aluminium option for the weight conscious
NOS EXUP
Post by NOS EXUP »
Yes thought about the weight before buying mine - but it is only 2mm thick and extremely sturdy . Its very light.
Would probably be just as heavy in aluminium as the sections would probably be thicker and more restrictive for air flow.
I thought about making my own but thats a serious cutting and filing job and no way could i achieve a finish as accurate as this cnc laser cut item.
falconman
Post by falconman »
Stainless is alot lighter than mild steel. That looks like a really nice piece. =D>
